Problem with LM339 comparator
Discussion in 'General Electronics Chat' started by samy555, Sep 22, 2015.
  1. samy555
    Thread Starter Active Member
    May 24, 2010
    116
    Hello
    I built this comparator using LM339 but it didn't work
    When I add a resistor (R6 = 1K) between VCC and pin #2 (the output pin of the first comparator), it works good
    My question is: What is the role played by that resistance?
    thanks
  2. Lestraveled
    May 19, 2014
    1,957
    1,218
    The LM339 comparators have an "open collector" output. They require a pull up resistor (R6). Google "open collector" for more info.
    samy555 likes this.
  3. crutschow
    Mar 14, 2008
    13,505
    3,378
    Of course the LM339 data sheet will also show that the output is open collector (but who looks at a data sheet? :rolleyes:).
    samy555 likes this.
  4. Bordodynov
    May 20, 2015
    673
    194
    This comparator with an open collector. Additional resistor gives current sourcing. The scheme can be simplified. Make R6 = 10kOhm. Remove the resistor R4. The base of the transistor connect to the output of the comparator.
    samy555 likes this.
  5. wayneh
    Sep 9, 2010
    12,391
    3,246
    At least he supplied a schematic, which made the answer immediately obvious. ;)
    #12, Sinus23 and shortbus like this.
  6. samy555
    May 24, 2010
    116
    Thank you very much
