I asked a few months ago on how to add a LED to a switch to indicate when the switch is off. Sgtwookie set me up with a plan here.
http://forum.allaboutcircuits.com/attachment.php?attachmentid=14037&stc=1&d=1259601684
This is the post.
http://forum.allaboutcircuits.com/showthread.php?t=30849
I built it on a breadboard and it work great. I had a red LED for off and a green LED when the the light was on.
I then built it into my dashboard for my motorcycle. It worked fine while testing it out.
I just wired into the motorcycle and it doesn't work now.
The switch will work to turn the headlight on and off. But the green LED is always on, and the red doesn't come on at all. I tried it with the test setup again and it did work.
Any idea how I should trouble shoot this? I can post a wiring diagram for the motorcycle if that will help. I think I might be getting some power back feeding and might need a diode.
Todd
This is the post.
Todd
