Problem with LCD 16 x 2 Display
Discussion in 'The Projects Forum' started by hunterage2000, Oct 22, 2012.
  1. hunterage2000
    Thread Starter Active Member
    May 2, 2010
    402
    I have purchased the attached LCD Display and it has come without instructions on how to use it. The datasheet shows what pin is what but nothing else. Does anyone know what I have to do to get it to work or at least show that it is not broken?
      File size:
      22 KB
      33
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
  3. hunterage2000
    May 2, 2010
    402
    I have an arduino and tried to test it using the attached image.
  4. MrChips
    Oct 2, 2009
    12,624
    3,451
    Note that the picture of the LCD on your breadboard does not match the one in your first post. But that's ok. The pinout might be different but they are functionally the same.
    Try replacing the 10kΩ contrast resistor with a 1kΩ resistor to GND.
    Also you are missing R/W control signal at pin-5.
  5. hunterage2000
    May 2, 2010
    402
    yeah, I forgot to mention the 16 x 1 pins in the text but I thought the 8 x 2 pins would be the same. So should R/W be gnd'd then?
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    It depends on the code of your program. If you wish to read back the BUSY status then your code will have to control R/W.
  7. olphart
    Sep 22, 2012
    5
    Howdy, you really do want to control R/W*. The variance of time delays in different commands make using Busy a big factor. Thankfully, most character based displays have 2 pinouts, both using the same functions by pin, just 1 as a single row, other as double.
    Once you write good stable LCD code Save Hell out of it. It's the kind of IP you'll use for a Long time... <<<)))
  8. Bob T.
    Member
    Oct 22, 2012
    35
  9. ScottWang
    Aug 23, 2012
    4,925
    777
