Problem with JFET/MOSFET
Discussion in 'Homework Help' started by PsySc0rpi0n, Jul 2, 2015.
  1. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Hi...
    I have started a new problem to try to solve.
    The circuit is attached and we are supposed to calculate Q-point for both transistors.
    So the first thing I did was to use Thevenin theorem and calculate Vth and Rth for the Voltage divider at the JFET gate.
    I found that Vth = 2V and Rth = 90kΩ
    Then I've used the device Id equation and the gate net equation to find Id and Vgs.
    Assuming that the JFET is working at it's active zone
    Id = Idss(1-(Vgs/Vpoff))^2
    and
    Vth + Rth*Ig + Vgs + Rs*Id = 0
    From the FET's theoretcial characteristics we are know Ig to be 0A, so:
    Rth*Ig = 0V
    So I got 2 solutions from the quadratic Id equation:
    Vgs = -9.26V and Id = 7.26mA
    and
    Vgs = -3.24V and Id = 1.24mA
    Now, I'm supposed to find out Vds to confirm or not the initial assumption. It's here that I have a question.
    Because there is no voltage drop at the MOSFET (transistor at the right side), can I simply write the JFET output net equation as:
    20 = Vds + Rs*Id ????
    • 4.asc
      File size:
      1.3 KB
      File size:
      24.8 KB
      23
  2. PsySc0rpi0n
    Mar 4, 2014
    1,191
    Ok, I think I got the final result even without any help from here!
