Problem with IR2117 High side gate driver
Discussion in 'Power Electronics' started by hunterage2000, Oct 1, 2016.
  1. hunterage2000
    Thread Starter Active Member
    May 2, 2010
    402
    I have simulated the attached circuit without anything connected to HO output. I have a 5V square wave going into IN and a 10V square wave coming out of HO.
    Now I have set the same circuit up on a breadboard and done the same thing but I have a 20V constant voltage coming out of HO.
    Not sure why this is the case. Does anyone know what could be the problem here?
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    What is the value of the capacitor betwen the Vs and Vb ?
    The datasheet shows a 0.1 μF.
    Also what is the value of Vcc?
    What is the value of Vs?
    Vb will be about Vs+Vcc.
    Bertus
  3. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    bertus likes this.
  4. hunterage2000
    May 2, 2010
    402
    1. The value is 4.7uF electrolytic between Vb and Vs. Didn't see a value of 100nF on the datasheet.
    2. VCC is 20V
    3. VS was about 20V
    4. VB was 19.9V (0.1V drop from diode)
  5. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    The bootstrap capacitor is also sized to the frequency of the PWM.
    See link.
    Max.
  6. shortbus
    Sep 30, 2009
    4,096
    1,692
    Don't most mosfet driver App notes say not to use electrolytic caps for that?
  7. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    shortbus likes this.
  8. ronv
    Nov 12, 2008
    3,402
    1,477
    If you are trying to run the IC by itself you need something from Vs to ground or HO won't go to ground.
