Problem with FM Modulation
Discussion in 'Programmer's Corner' started by ashwini1, Aug 12, 2009.
  1. ashwini1
    Aug 1, 2009
    9
    I am facing problem with fm modulation and demodulation.
    i want to design a fm modulation with the following specs:
    fm = modulating freq = 30Hz
    fc = carrier freq = 10kHz
    dev = frequency deviation = 480Hz
    The problem is that for the carrier freq more than 1kHz, is not getting modulated properly which can be confirmed at demodulation.
    Plz find below the matlab code:
    fc=1e3;
    Fs=10*fc;
    t=(0:Fs)'/Fs;
    L=1000;
    fm=30;
    ph=0;
    dev=480;
    NFFT=2^nextpow2(L);
    f=Fs*linspace(0,1,NFFT);
    %%---- FM ----%%
    x=1*cos((2*pi*fc*t)-(dev/fm)*1*sin(2*pi*fm*t+(ph*pi/180)));
    [num den]=butter(1,(fc+30+30)/(Fs/2)); % -3db @ 10Hz
    x1 = filtfilt(num,den,x); % leave DC
    %%---- FM DEMOD ----%%
    yq = hilbert(x1).*exp(-j*2*fc*t);
    y = (1/(2*pi*dev))*[zeros(1,size(yq,2)); diff(unwrap(angle(yq)))*Fs];
    [num den]=butter(1,25/(Fs/2),'high');
    y = filtfilt(num,den,y);
    [num den]=butter(1,30/(Fs/2));
    figure;
    subplot(211)
    plot(t,y)
    subplot(212)
    plot(f,2*abs(fft(y,NFFT)/L))
    axis([0 200 0 4])
    Kindly go through the code and help me in debugging it.
    Is there any constraint in selecting modulating frequency and carrier frequency.??
    Thanks and Regards,
    Ashwini
  2. ashwini1
    Aug 1, 2009
    9
    Few more doubts:
    1) Is my method of demodulation is correct??? What are other ways where i can get back my original signal more faithfully.
    2) Is there any constraint in selecting modulating frequency and carrier frequency??
    3) How do i correlate Fs, fc, freqdev and fm.
    Thanks !
    Ashwini
