Problem with eq of Line Segment
Discussion in 'Homework Help' started by zulfi100, Dec 29, 2013.
  1. zulfi100
    Jun 7, 2012
    320
    Slide 11 on the following link is showing two eq:
    I got this from:
    www.cse.msu.edu/~cse472/lectures/14.pdf‎
    Line from (x1,y1) to (x2,y2)
    x = x1 + u(x2 - x1)
    y = y1 + u(y2 - y1)
    Can some body plz guide me how we got the above two eq.
    Zulfi.
  2. studiot
    Nov 9, 2007
    5,005
    515
    The link doesn't work for me.
    But think about what happens if x2 = x1; what is x? in the first equation?
    similarly if y2 = y1; what is y in the second equation?
  3. WBahn
    Mar 31, 2012
    18,089
    4,917
    We've been through this more than once already!
    What is x and y if u=0?
    What is x and y if u=1?
    These are both linear equations. If two parametric linear equations go through two points, then they describe the line that connects those two points.
