Problem with Camera Board
hugocodi
Joined Mar 5, 2016
44
I recently got this camera sensor ttp://www.aliexpress.com/snapshot/7293055509.html?orderId=72676672140705
It is a 1/3" NVP 2421 CMOS + Panasonic 34227 DSP. I have bought sensors like this one in the past and I never had any problems but with this one I get this weird digital noise with either the SDI or the composite signal. I can still navigate through the menu, I have reset the settings switched between PAL to NTSC but it stays the same.
The store is not being of much help, they only offer partial refund so I am hoping that maybe I could fix it.
Any idea on what that would be?
Thank you so much!
bertus
Joined Apr 5, 2008
22,277
As nerdegutta said, you will need a lens.
You can see the holes next to the sensorchip.
Those are for mounting the lens fixture.
Bertus
Alec_t
Joined Sep 17, 2013
14,314
It's a job to tell from the pics, but the soldering on some of the components looks less than perfect. If a decoupling cap somewhere had a dry joint you might expect digital noise breakthrough.
