Problem with BTFSC instruction Pic16f877A in PICC
Discussion in 'Embedded Systems and Microcontrollers' started by anhnha, May 24, 2012.
  1. anhnha
    Thread Starter Active Member
    Apr 19, 2012
    776
    48
    Hi everyone,
    I have a problem with BTFSC in PICC with pic16f877A.I used the following code but it seem that BTFSC do not work.Both bits of portc always is set.
    Code ( (Unknown Language)):
    1.
    2. BTFSC 0x4F,1
    3. bsf portc, 5
    4. bsf portc, 6
    5.
    Could you help me this?
    Thanks in advance.
  2. John P
    Oct 14, 2008
    1,638
    225
    Does anything ever clear Portc 5 and 6? If you only set them and never clear them, you shouldn't be surprised if they're always set.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    How did you test this? Did you just simulate or test it in a circuit. It is hard to tell anything from the code you posted. For all I know you can be in the wrong memory bank. Or the TRISC register may have the wrong setting. Can you post all your code?
