problem with ATMEGA 32U4 controller
Discussion in 'The Projects Forum' started by vivek20055, Apr 24, 2013.
  1. vivek20055
    Nov 4, 2012
    88
    I am working on Atmega 32u4 controller.
    I have a problem with the controller in my circuit.
    My controller is not detecting when the usb is plugged in.
    I checked the Vcc,GND and crystal oscillator connections which are perfect.
    Is there any other connections which I need to check to figure out the problem.
    This controller is having the factory default boot loader or I need to dump the boot loader for the working of the controller.
    Regards
    Vivek Alaparthi
  2. kubeek
    Sep 20, 2005
    4,687
    805
    Please post a schematic of how you have it connected right now.
    aws505 likes this.
  3. vivek20055
    Nov 4, 2012
    88
    I am adding the schematic here
    The pdf contains the controller circuit on the right hand side on the top
    please check it and give comments on it
  4. OldSkoolEffects
    Member
    Nov 18, 2009
    68
    This chip apparently needs some massaging to get it reading correctly. I have one on a https://www.sparkfun.com/products/11098 and had to follow their tutorial to get things working correctly.
