Problem with at89c51ac3
Discussion in 'Embedded Systems and Microcontrollers' started by guilla, May 11, 2013.
  1. guilla
    May 11, 2013
    Hello, I'm working with an atmel microcontroller, concretely with the at89c51ac3-SL3SUM microcontroller (the one which is a plcc-52 package) and it works fine, fine until I surpass a code size of 3380 bytes concretely, the main routines do work well, the problem is that the timers even though I do a timer run, they don't work and I can'¡t understand the problem, might any of you help me in solving this error?
    Tell me if you need the code of the program.
  2. ErnieM
    Apr 24, 2011
    7,433
    1,623
    With the invention of the Enhanced Surveillance Proxy (ESP) applet freely available anyone at anytime can see all your computer files and even your workbench to check out the hardware.
    No need to provide any details at all.
