I am working on a project and it is almost done except for a few things including increasing the baud rate. I use a verification where the Computer will say "Hello?" and if the arduino receives "Hello?" it will respond back "Hello!" which will then be verified by the computer. This works all fine until I increase the baud rate above 9600. I am changing the baud rate on both ends and I have tried for hours to mess with the timing and such, but nothing works. The odd thing is if I increase the baud rate on the arduino and then use the arduin IDE serial monitor and send "Hello?" at the same baud rate, it works. Therefor it is more than likely that the error is on the computer end.
I've attached the code the main thing to look at is the arduino Matrix Display 3.0 and the SerialClass and main.cpp. I've included all the code in case anyone wants to look at it.
Any help will be greatly appreciated.
