problem with analog ground(AGND)
Discussion in 'The Projects Forum' started by vivek20055, Feb 11, 2013.
  1. vivek20055
    Nov 4, 2012
    88
    I am designing a 4 layer pcb board. For the GND layer I have given seperate GND ground for high current path(from transistors) which is connected to normal GND at a point.
    I have given the seperate analog ground(AGND).
    My professor commented like this:
    If you only have analog parts over the analog GND then it is good that you are using a separate analog gnd but I am surprised that the analog part is so spread. A problem might be that your analog GND is connected at the end of the digital GND and digital noise will be added to your analog gnd. A start connection to the common GND separation might improve.
    what does this mean?????
    How can I add start connection???
    I am adding image with this message
    Regards
    Vivek Alaparthi
      File size:
      35.1 KB
      19
  2. Sensacell
    Jun 19, 2012
    1,186
    277
    I believe your Professor means "Star Connection" - Google this.
  3. vivek20055
    Nov 4, 2012
    88
    I need to use star point grounding connection for AGND and GND in PADS software??
    I have seperate copper areas for GND and AGND in my 4 layer pcb design.
    How can I implement star point grounding connection for AGND and GND???
    I am attaching the image for AGND and GND of my design???
    Regards
    Vivek
      File size:
      35.1 KB
      14
