Problem with adxl362
Discussion in 'Embedded Systems and Microcontrollers' started by iknaite, Jan 15, 2013.
Thread Status:
Not open for further replies.
  1. iknaite
    May 23, 2012
    10
    How to make ADXL362 INT pin high by acceleration without providing power to the microcontroller. After detection of motion INT pin will goes high then power is provided to the microcontroller.
    ie, If motion is detected power should be provide to the microcontroller , otherwise no power (means power is source is connected with the switch which enable pin, if enable pin is high the switch is close).
  2. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    You already have a thread for this:
    adxl362
    Please do not start new threads for the same problem.
    Bertus
Thread Status:
