Problem- vacuum diode
Discussion in 'General Electronics Chat' started by tam72f1, Dec 21, 2014.
Thread Status:
Not open for further replies.
  1. tam72f1
    Aug 19, 2014
    15
    Hi all!
    I used this diode to design a full-wave rectification but wave is displayed on Mutilsim that incorrect with theory!
    Can anyone help me to repair this circuit!
    Thank you so much!
    Lundwall_Paul likes this.
  2. MaxHeadRoom
    Jul 18, 2013
    10,833
    2,502
    You have both AC and DC referenced to the same common point for one.
    Max.
  3. crutschow
    Mar 14, 2008
    13,477
    3,362
    I don't see any problem with your circuit, which appears to be a standard full-wave rectifier configuration designed to give a negative voltage output (is that the intention?) and should show two negative peaks per cycle, not one. Perhaps your tube model has a problem.
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    there is a problem, why do you have both the plate tap and the filament tap grounded? if you are trying for + output, unground the filament tap, and use it for output to filters.
  5. MaxHeadRoom
    Jul 18, 2013
    10,833
    2,502
    Suggestion:
    Max.
  6. Lundwall_Paul
    Oct 18, 2011
    222
    19
    Vacuum tubes I love it.
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    If you're only getting half-wave rectified output - try reversing the phase of one of the secondaries feeding the anodes.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
Thread Status:
