Maybe I can get help in this forum.
Proper numbers are returned except when the 'tone' function is added.
After first time only '0' is returned.
Code:
IR_remote_detector sketch
An IR remote receiver is connected to pin 11. Have tried 2-6 & 11.
Decode problem when using tone function. Always returns 0 after first time.
The LED on pin 13 toggles each time a button on the remote is pressed.
#include <IRremote.h> //adds the library code to the sketch
const int irReceiverPin = 11; //pin the receiver is connected to
const int ledPin = 13;
IRrecv irrecv(irReceiverPin); //create an IRrecv object
decode_results decodedSignal; //stores results from IR detectorvoid setup()
unsigned long value;
void setup ()
Serial.begin(9600);
pinMode(ledPin, OUTPUT);
irrecv.enableIRIn(); // Start the receiver object
boolean lightState = false; //keep track of whether the LED is on
unsigned long last = millis(); //remember when we last received an IR message
void loop()
if (irrecv.decode(&decodedSignal) == true) //this is true if a message has
//been received
value = decodedSignal.value;
delay(200); // extra debounce
Serial.print(value);
Serial.print(" ");
tone(8,600,100); // comment out this line and the IR receiver works as expected!
if (millis() - last > 250) { //has it been 1/4 sec since last message? debounce?
lightState = !lightState; //Yes: toggle the LED
digitalWrite(ledPin, lightState);
last = millis();
irrecv.resume(); // watch out for another message
