Problem using 74HC4017
Discussion in 'The Projects Forum' started by xisco, Mar 2, 2010.
  1. xisco
    Mar 2, 2010
    14
    To whom it may concern,
    I am doing my final year project (Multi-loop PLL frequency synthesizer) and I am using this counter in order to divide the frequency. I am finding some dificulties to achieve the division. In the date sheet provided by NXP there is a schematic to achieve division by 2 through 10. I have implemented this circuit however, I have not been able to divide, I would be grateful if someone could help me.
    Thank you,
    Best regards,
    Francis
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Hello Francis,
    The first thing you should do is to post a schematic of how you have things wired up right now.
    A schematic tells a rather complete story using almost no words. This will help us help you much more quickly.
    Note that 74 series ICs have a fairly limited range of voltages that they will operate correctly on.
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Can you post the schematic of the circuit you have upto now?
    Preferred is a drawing in .png format.
    Greetings,
    Bertus
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    A CD4017 and a 74HC4017 has one output connected to its reset pin to make a frequency divider.
  5. xisco
    Mar 2, 2010
    14
    Hello to all,
    First of all I would like to thank you your responses!!. I have attached to this message a schematic (from the data sheet, I am trying the find the spice simulation model to do it on DXP and I thought almost everyone would have paint) I have implemented this circuit with the only change of MR instead being connected to the divide by 3 pin it is connected to the divide by 10 pin. But it is giving me the same output frequency as the input frequency. However, I tried different connections and I finally was able to achieve division by 10 by not connecting MR to the divide by 10 pin. I was wondering how this can happen I have achieved what i needed now but in my project I need to divide also by 9 and at the moment I am trying to know why it is not working and how to make it work.
    Best regards,
    Francis,
