Problem to draw a two level 4x1 MUX
Discussion in 'Homework Help' started by nori90, Mar 21, 2011.
  1. nori90
    Mar 21, 2011
    Hello Everyone,
    I have
    4 Inputs A,B,C,D and outputs is high for (0,3,6,9,12).
    I found the truth table and I now have to plot a two level of 4x1 MUX
    I have trouble to do it :0
    I know how to do it using only one MUX but now I am really struggling
    Thanks for your answer and help
    Nori
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    I take it you will use 2 4x1 MUXs for the first level and another 2x1 MUX for the final selection.
    Break your truth table in rows of 8. That will result in 2 separate tables. Use only the columns B,C and D to produce a partial solution of the problem. That way you will have a result that is valid only if A=0 and another that stands when A=1.
    Use the 2x1 MUX controlled by the input A to filter the two results. Presto! You have your result.
