Problem: ScanLine Filling Algorithm
Discussion in 'Homework Help' started by zulfi100, May 2, 2014.
  1. zulfi100
    Jun 7, 2012
    320
    I am trying to fill a polygon using scanLine filling algorithm. At scanline 4, it is not filling correctly. The polygon is attached in the image file. My work is given below:
    All Edge Table
    0 (1,1)
    1 (5,1)
    2 (5, 3)
    3 (8, 3)
    4 (8, 8)
    5 (4, 8)
    6 (4, 4)
    7 (1, 4)
    Global Edge Table
    Index Ymin Ymax Xval 1/m
    0 1 1 1 infinity
    1 1 3 5 0
    2 3 3 5 infinity
    3 3 8 8 0
    4 8 8 4 infinity
    5 4 8 4 0
    6 4 4 1 infinity
    7 1 4 1 0
    Global Edge Table
    0 1 3 5 0
    1 3 8 8 0 (X)
    2 4 8 4 0 (X)
    3 1 4 1 0
    ScanLine=1, choose all edges where Ymin=1
    Active Edge Table
    Index Ymax Xval 1/m
    0 3 5 0
    1 4 1 0
    Reordering (Xvalues are not sorted):
    Index Ymax Xval 1/m
    0 4 1 0
    1 3 5 0
    Filling:
    Scanline =1, At x=1, Parity is odd so fill all points from x=1 to x=5. Parity becomes odd so stop filling.
    (The web document says until x=5 which is also wrong)
    Update the x-values. No change.
    Index Ymax Xval 1/m
    0 4 1 0
    1 3 5 0
    ScanLine=2, At x=1, Parity is odd so fill all points from x=1 to x=5. Parity becomes odd so stop filling.
    (As discussed earlier, the web document says until x=5 which is also wrong).
    Since Ymax for edge indexed 1 is 3 which is the next scanLine, we would remove this edge from Active Edge Table:
    Index Ymax Xval 1/m
    0 4 1 0
    1 8 8 0 //Adding remining edges marked as (X) in global edge table
    2 8 4 0
    Reordering :
    Index Ymax Xval 1/m
    0 4 1 0
    1 8 4 0
    2 8 8 0
    ScanLine=3, At x=1, parity is odd, so fill all points from x=1 to x=4. Parity is still odd so filling will continue upto x=8. Since next scanline is equal to 4 which is the Ymax value at index=0 so we would remove it from Active Edge Table.
    Index Ymax Xval 1/m
    0 8 4 0
    1 8 8 0
    ScanLine=4, At x=4, parity is odd so fill all points from x=4 to x=8. Parity becomes odd no filling.
    PROBLEM: We are not filling points fromx=1 to x=3??
    The problem is that we are not filling the points from x=1 to x=3 when scanline=4. I have also attached a text file, if there is problem in formatting of tables. Somebody plz guide me.
    Zulfi.
