Hi all,
I'm currently developing software application to run on my nios processor using Nios2 SBT.
I have designed my board to glow the LED's depending on the values it reads from the register. I'm developing software to write into the register through Avalon bus interface. But, to get the BSP's and other files required i used an existing example from the templates( Hello world small) and generated BSP's and built the project. So out of curiosity i tried running Hello world small .elf file generated on my board. But i get the following message when i download the .elf on my board
" Pausing target processor : Not responding
Resetting and trying again : OK
Initiating CPU cache <if present>
OK
Downloaded 1KB 0.0s\Verified OK
Starting processor at address 0x00008020"
Then when i try and run it it does not work but terminates.
So my question is "Is it because my board is designed to function differently from the developed software or is there any other problem"
Please help.
OK
Please help.
