Problem regarding burning program in Microcontroller
Discussion in 'Embedded Systems and Microcontrollers' started by shom_show, Apr 11, 2012.
  1. shom_show
    Sep 4, 2010
    15
    Hi to all,
    I have choose the option of atmega32 in extreme burner -avr. But trying to write the program in the microcontroller chip it is showing the following message -
    > Autodetecting programmer
    > Found USBasp on USB port
    > Powering ON
    > Powering failed
    > Cannot communicate with target chip
    > Retrying again
    > Power on failed
    > Repeating the above three
    > Powering off
    > Power turned off
    > ******Task failed*******
    > *******Please retry again*******
    > Thank you
    Can you anyone please address the problem. Waiting for your response
    Sumanta
  2. shom_show
    Sep 4, 2010
    15
    It would be better if you please reply in my Email Id -
    <SNIP>
  3. chrisw1990
    Oct 22, 2011
    543
    41
    never gonna happen.
    havent used AVR chips before, or with this programming method.. does it need the device to be programmed?
    is the target board soldered correctly?
  4. MrChips
    Oct 2, 2009
    12,648
    3,458
    Did you monitor the power being applied to the target MCU?
    Did you try applying power to the target MCU directly?
  5. bug13
    Feb 13, 2012
    1,214
    38
    I am new to uC, but it looks like a connection problem:
    -check the power supply at your uC
    -check your wiring
  6. be80be
    Jul 5, 2008
    432
    57
