problem on trapezoidal estimate.
Discussion in 'Math' started by MichealY, Aug 25, 2009.
  1. MichealY
    Thread Starter Active Member
    Apr 9, 2009
    49
    \int_0^1 \frac{dx}{1+x^5} = ?
  2. Mark44
    Nov 26, 2007
    626
    Based on the title of this thread, the estimate is supposed to be done by using a trapezoidal approximation. To do this, divide the interval [0, 1] into some number of subintervals (the more subintervals, the better the approximation).
    For example, if you divide this interval into four subintervals you will have five points on the graph of your function: (0, f(0)), (.25, f(.25)), (.5, f(.5)), (.75, f(.75)), and (1, f(1)). Using each successive pairs of points, calculate the area of the trapezoid that is formed. Add the areas to get an approximation of the definite integral.
  3. ELECTRONERD
    May 26, 2009
    1,146
    16
    You're quite the mathematician, Michael! ;)
  4. KL7AJ
    Nov 4, 2008
    2,043
    292
    Wasn't this the general concept of the LIMIT in the first place? :D
  5. Mark44
    Nov 26, 2007
    626
    The Riemann integral is defined as a limit of sums similar to the above, so to answer your question, yes, sort of.
