problem in single supply op amp simulation
Discussion in 'General Electronics Chat' started by spidermanIIII, Mar 29, 2015.
  1. spidermanIIII
    Nov 22, 2013
    76
    hello, we asked to simulate this signal conditioning examples in Proteus the example is case 3 and case 4 the problem when i put the input which is negative the out put is always 5 volt please i need help to simulate the case 3 and 4 examples in pdf file what is the wrong in my simulation
  2. wayneh
    Sep 9, 2010
    12,403
    3,249
    Can the op-amp you are using sense voltages as close to the power rails as in the TI examples? I suspect you are operating outside the common-mode range.
  3. crutschow
    Mar 14, 2008
    13,511
    3,385
    Please post as standard graphic or pdf files.
    I cannot read the Proteus files.
  4. spidermanIIII
    Nov 22, 2013
    76
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    What is the RG thing in the upper left corner. Is it a voltage source, or a probe to show the voltage there?
  6. spidermanIIII
    Nov 22, 2013
    76
    it is a voltage source
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    Looking at case 3: What is the voltage at the + (non-inverting) input?
    What is the allowed input common-mode range for this amplifier when it is operated from 0V and 10V?
    Why is the ratio of R1 to R2 what it is?
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    Looking at case 4: The voltage at the + (non-inverting) input is zero tied to ground.
    Considering that the output swing of the LM324 is from near oV to 10V-1.5V = 8.5V, and that the current injected by R1, R2 from the 5V bias source is tiny, what is the allowed input range from RG2 that would keep the opamp in its linear region (simple algebra, you dont need a simulator)?
