Problem in RS485 interface
Discussion in 'General Electronics Chat' started by sanddune, Feb 10, 2009.
  1. sanddune
    Dec 2, 2008
    10
    Hi All,
    Prj Description:
    I am designing a hub which receives i/p's(max of 4 inputs) from actuators and slaves connected to the hub(output). When an actuator input is received Master(Hub) will process it and sends a common command to all the salves connected to its output....based on the command each slave will do the necessary.
    Now the problem is the slave receives data which is contains noise and hence displays junk day to the LCD........
    Can anyone please verify my schematics.....which is attached.
    Also attached is my slave input(
    yellow w/form) and master output(blue w/form)......
    Thanks in advance...........
  2. sanddune
    Dec 2, 2008
    10
    I am sending "Hello world" at baud rate: 384000
  3. sanddune
    Dec 2, 2008
    10
    can some one explain what could be the reason for the noisy signal at the slave output to the Micro controller?.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I would question the 100 ohm resistors between the Max485 ground pins and circuit ground. Try removing them (put the ground pins directly to ground) and see if things don't start working.
