problem in providing toggle inputs to an 8051 microcontroller.
Discussion in 'Embedded Systems and Microcontrollers' started by jadedcynic, Jun 13, 2010.
  1. jadedcynic
    Jun 13, 2010
    hi,
    i am working on a device which will turn on or off the lights in a room depending upon whether the room is occupied or not. i am using the TSAL6200 as my ir transmitter and an ir detector(the one that looks like an led). two of these tx rx pairs are placed at the entrance to the room and depending on whether the external one gets blocked first or the internal one the count value increments or decrements. now my ir receiver seems to be working fine, i.e. it gives me a low voltage(about 0.2v ) in the absence of ir light and a high of about 2.67 in the presence of the ir light.
    PROBLEM :
    i am trying to give the output of my ir receiver to my uc. i am using the port 1 and the pins 1.0 and 1.1. the problem is that for me to set the uc port as an input port all of its pins need to be set to 0xFF(in c language), i.e. they all have a voltage of 5v, so when i try to force feed the output of my ir receiver to the uc all that happens is that the current flows from the higher potential to the lower potential and lights up the test leds of my circuit. the uc is not accepting my input.
    i need the uc to be able to read the high and the low voltages which i am feeding it.
    do i need to use the interrupt pins of port 3 for the uc to be able to accept my toggle inputs?
    also in my program i am simply using two nested if conditions, do i need to use the counter section of the uc?
    this is my initial program:
    <reg51.h>
    bit ir1=p1^0;
    bit ir2=p1^1;
    bit relay = p2^3;
    int count=0;
    //declarations
    //ir1=0;//make p1.0 low
    //ir2=0;//make p1.1 low
    void delay(void)
    int i;
    for(i=0;i<30000;i++)
    void main(void)
    while(1);
    P1=0XFF;\\set port 1 as input
    P2=0;\\set port two as output
    if(ir1==0)
    delay();
    delay();
    delay();
    delay();
    if(1r2==0)
    count=count+1;
    else if(ir2==0)
    delay();
    delay();
    delay();
    delay();
    if(ir1==0)
    count=count-1;
    if(count==0)
    relay=0;
    if(count!=0)
    relay=1;
    help me please!!:(:confused:
