hi,
we are making project "IC tester" using PIC16F877a. we had successfully load the program to the PIC... the problem is there's no output. the supplied voltage is 5V. when we checked the voltage across the IC, only 3V was measured. is the measured voltage across the IC which is 3V is the possible cause or reason why we obtain negative result?
(there's no output in the LED display)
Are we going to use transistor to amplify the voltage?
