problem in my Fm transmitter
Discussion in 'The Projects Forum' started by haithem alsaab, Aug 8, 2013.
  1. haithem alsaab
    Aug 8, 2013
    12
    Hello every body
    I'm glad to register in this forum it is one of the good forums that I've seen.
    Dears I have a project which is about creating a Fm transmitter I went to the shop and I find all the component except some capacitors
    that I fell to find it so I forced to create these value by adding capacitors in parallel or series
    this scheme of the project
    this is after the modification
    and this is real pic
    my question I'm I right when I replace the C
    the second question I fell to make it work and I really do not know why can you guess where is the problem
  2. #12
    Nov 30, 2010
    16,664
    7,311
    You used the wrong kind of board to connect the parts. Use a printed circuit board.
  3. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    You can't build high frequency circuits on a breadboard.
  4. absf
    Dec 29, 2010
    1,493
    374
    here is an example how you should layout your FM circuit.
    Allen
  5. Sensacell
    Jun 19, 2012
    1,183
    276
    What you need to understand is that the solderless breadboard you are using has lots of stray capacitance between connections, imagine if you connected 10pf capacitors between every connection point, at 100 mhz this causes havoc.
    Also- at these frequencies, even the length of one jumper wire has significant inductance.
    Building RF circuits requires a totally different way of looking at layout and construction practice.
  6. haithem alsaab
    Aug 8, 2013
    12
    thank you all
    Thank you for your quick response. I really appreciate your
    so guys
    how can I use redesign ,so that it can work in this board even if I change the freq the important point is to make it work as an Fm trans ?
  7. Mussawar
    Member
    Oct 17, 2011
    68
    There is another issue. Avoide using the combination of capacitors and resisters. RF circuits are very senstive so can't be assembaled roughly. Try to use the nearest available values. Best idea is to get parts from some old RF PCB (TV or Radio). You might get the exact values from here. Once I have made this type of circuit. Your coil would give you a relaxation. Changing the distance bw turns will change the freq so you can compensate the PF capacitor's values. Infect assembling the RF circuits need professional hands. Even a bad layout will mess up you circuit. If you can’t make a PCB, you can try this: Draw a PCB layout on a hard plastic sheet and drill it as it was a PCB. Now mount the parts and make connections by using a jumper wire exactly on the layout pattern. (I used this method for the first time and was successful). Q2 is the key portion of the transmitter. If you succeded to tune it somewhere in the entire FM range (88Mhz to 108Mhz) you got it. Rest of the circuit is just a Mic Pre Amplifier and would be easy to assemble. Wish you gud luck.
  8. bertus
    Administrator
    Apr 5, 2008
    15,797
    2,384
    You might want to have a look at the following PDF:
    rf_proto-1.pdf
    Bertus
    #12 likes this.
  9. haithem alsaab
    Aug 8, 2013
    12
    all guys above thank you very much
    really I'm proud to be with you
    In summary , I have to use a printed circuit board right ?
  10. #12
    Nov 30, 2010
    16,664
    7,311
    That and a lot of education.
  11. haithem alsaab
    Aug 8, 2013
    12
    ok I'll work hard and hard until I beat you:D
    #12 likes this.
  12. Sensacell
    Jun 19, 2012
    1,183
    276
