yes , if use calculator will get (-3+1.732j) , (-3-1.732j)Check your simplification.
You should have
\( \frac {40}{s^2+6s+12}=\frac {40}{ \(s+3\)^2+\({\sqr {3}}\)^2\)
A calculator isn't necessary. The manipulation in post #2 should be readily appreciated by the observant student.yes , if use calculator will get (-3+1.732j) , (-3-1.732j)
thanks
You need to become familiar with completing the square. You also need to stop relying on tools like Wolfram Alpha and a calculator to do your thinking for you. It's one thing to use them to verify your work or to ease the grunt work, it's another to just turn to them because you can't work it out yourself. The distinction between proper and improper use of these kinds of tools is very gray and malleable, but you want to try to develop and maintain your ability to do your own thinking.yes , if use calculator will get (-3+1.732j) , (-3-1.732j)
thanks
The mind needs to solve complex logic problems to remain sharp... pretty much like muscles need a basic level of weight lifting to keep functional and the rest of the body in good shape...... you want to try to develop and maintain your ability to do your own thinking.
Thread starter | Similar threads | Forum | Replies | Date |
S | RC circuit/Laplace transform/homework problem | Homework Help | 7 | |
problem from laplace | Homework Help | 12 | ||
O | Problem in circuit laplace and switch | Homework Help | 38 | |
X | Laplace transform problem | Homework Help | 5 | |
Sign convention problem for laplace transform? | Homework Help | 1 |
by Aaron Carman
by Duane Benson
by Duane Benson
