Problem in ISIS configuration trafo
Discussion in 'The Projects Forum' started by MrYu, Aug 14, 2012.
  1. MrYu
    Sep 26, 2011
    42
    how to configure this in trafo or the alternator. i get 50v before the voltage regulator 7812/7805
  2. t06afre
    May 11, 2009
    5,939
    1,222
    You may use the formula on page 1 in this document http://www.ecse.rpi.edu/courses/EI/transformer_notes.pdf
    However I try to avoid simulating transformers in Spice. Unless I have all the transformer data at hands. Most often you will only have a given secondary voltage at a a given primary voltage and max load current
