Hello Everyone,
Kindly anyone could help me, I am making a Glcd based clock with ds1307 rtc using pic 18f4520,I am using HS oscillator of 20Mhz. My Glcd(12864a) is working fine and I have also checked rtc(also using 32khz crystal for drving the rtc ) through oscilloscope. I am not able to find why my clock is not working and It only displays one digit ascii character and keeps blinking always. I am attaching my source code. I am using MikroC pro for Pic compiler and pic kit 3 programmer in .
Rich (BB code):
// Glcd module connections
char GLCD_DataPort at PORTD;
sbit GLCD_CS1 at LATB3_bit;
sbit GLCD_CS2 at LATB4_bit;
sbit GLCD_RS at LATB0_bit;
sbit GLCD_RW at LATB1_bit;
sbit GLCD_EN at LATB2_bit;
sbit GLCD_RST at LATB5_bit;
sbit GLCD_DB0 at LATD0_bit;
sbit GLCD_DB1 at LATD1_bit;
sbit GLCD_DB2 at LATD2_bit;
sbit GLCD_DB3 at LATD3_bit;
sbit GLCD_DB4 at LATD4_bit;
sbit GLCD_DB5 at LATD5_bit;
sbit GLCD_DB6 at LATD6_bit;
sbit GLCD_DB7 at LATD7_bit;
sbit GLCD_CS1_Direction at TRISB3_bit;
sbit GLCD_CS2_Direction at TRISB4_bit;
sbit GLCD_RS_Direction at TRISB0_bit;
sbit GLCD_RW_Direction at TRISB1_bit;
sbit GLCD_EN_Direction at TRISB2_bit;
sbit GLCD_RST_Direction at TRISB5_bit;
sbit GLCD_DB0_Direction at TRISD0_bit;
sbit GLCD_DB1_Direction at TRISD1_bit;
sbit GLCD_DB2_Direction at TRISD2_bit;
sbit GLCD_DB3_Direction at TRISD3_bit;
sbit GLCD_DB4_Direction at TRISD4_bit;
sbit GLCD_DB5_Direction at TRISD5_bit;
sbit GLCD_DB6_Direction at TRISD6_bit;
sbit GLCD_DB7_Direction at TRISD7_bit;
// End Glcd module connections
unsigned short read_ds1307(unsigned short address)
unsigned short r_data;
I2C1_Start();
I2C1_Wr(0xD0); //address 0x68 followed by direction bit (0 for write, 1 for read) 0x68 followed by 0 --> 0xD0
I2C1_Wr(address);
I2C1_Repeated_Start();
I2C1_Wr(0xD1); //0x68 followed by 1 --> 0xD1
r_data=I2C1_Rd(0);
I2C1_Stop();
return(r_data);
void write_ds1307(unsigned short address,unsigned short w_data)
I2C1_Start(); // issue I2C start signal
I2C1_Wr(0xD0); // send byte via I2C (device address + W)
I2C1_Wr(address); // send byte (address of DS1307 location)
I2C1_Wr(w_data); // send data (data to be written)
I2C1_Stop(); // issue I2C stop signal
unsigned char BCD2UpperCh(unsigned char bcd)
return ((bcd >> 4) + '1');
unsigned char BCD2LowerCh(unsigned char bcd)
return ((bcd & 0x0F) + '1');
int Binary2BCD(int a)
int t1, t2;
t1 = a%10;
t1 = t1 & 0x0F;
a = a/10;
t2 = a%10;
t2 = 0x0F & t2;
t2 = t2 << 4;
t2 = 0xF0 & t2;
t1 = t1 | t2;
return t1;
int BCD2Binary(int a)
int r,t;
t = a & 0x0F;
r = t;
a = 0xF0 & a;
t = a >> 4;
t = 0x0F & t;
r = t*10 + r;
return r;
int second;
int minute;
int hour;
int hr;
int day;
int dday;
int month;
int year;
int ap;
unsigned short set_count = 0;
short set;
char *time = "00:00:00 PM";
char *date = "00-00-00";
void main()
I2C1_Init(100000); //DS1307 I2C is running at 100KHz
ADRESL = 0;
ADRESH = 0;
CMCON = 0x07; // To turn off comparators
ADCON1 = 0xFF; // To turn off analog to digital converters
TRISA = 0x07;
PORTA = 0x00;
Glcd_Init(); // Initialize GLCD
Glcd_Fill(0xFF);
Delay_ms(100);
Glcd_Set_Font(Font_Glcd_Character8x7, 8 , 7, 32);
Glcd_Write_Text( "Time:" , 80, 1, 2);
Glcd_Write_Text( "Date:" , 65, 5, 2);
do
set = 0;
if(PORTA.F0 == 0)
Delay_ms(100);
if(PORTA.F0 == 0)
set_count++;
if(set_count >= 7)
set_count = 0;
if(set_count)
if(PORTA.F2 == 0)
Delay_ms(100);
if(PORTA.F2 == 0)
set = 1;
if(PORTA.F0 == 0)
Delay_ms(100);
if(PORTA.F2 == 0)
set = -1;
if(set_count && set)
switch(set_count)
case 1:
hour = BCD2Binary(hour);
hour = hour + set;
hour = Binary2BCD(hour);
if((hour & 0x1F) >= 0x13)
hour = hour & 0b11100001;
hour = hour ^ 0x20;
else if((hour & 0x1F) <= 0x00)
hour = hour | 0b00010010;
hour = hour ^ 0x20;
write_ds1307(2, hour); //write hour
break;
case 2:
minute = BCD2Binary(minute);
minute = minute + set;
if(minute >= 60)
minute = 0;
if(minute < 0)
minute = 59;
minute = Binary2BCD(minute);
write_ds1307(1, minute); //write min
break;
case 3:
if(abs(set))
write_ds1307(0,0x00); //Reset second to 0 sec. and start Oscillator
break;
case 4:
day = BCD2Binary(day);
day = day + set;
day = Binary2BCD(day);
if(day >= 0x32)
day = 1;
if(day <= 0)
day = 0x31;
write_ds1307(4, day); // write date 17
break;
case 5:
month = BCD2Binary(month);
month = month + set;
month = Binary2BCD(month);
if(month > 0x12)
month = 1;
if(month <= 0)
month = 0x12;
write_ds1307(5,month); // write month 6 June
break;
case 6:
year = BCD2Binary(year);
year = year + set;
year = Binary2BCD(year);
if(year <= -1)
year = 0x99;
if(year >= 0x50)
year = 0;
write_ds1307(6, year); // write year
break;
second = read_ds1307(0);
minute = read_ds1307(1);
hour = read_ds1307(2);
hr = hour & 0b00011111;
ap = hour & 0b00100000;
dday = read_ds1307(3);
day = read_ds1307(4);
month = read_ds1307(5);
year = read_ds1307(6);
time[0] = BCD2UpperCh(hr);
time[1] = BCD2LowerCh(hr);
time[3] = BCD2UpperCh(minute);
time[4] = BCD2LowerCh(minute);
time[6] = BCD2UpperCh(second);
time[7] = BCD2LowerCh(second);
date[0] = BCD2UpperCh(day);
date[1] = BCD2LowerCh(day);
date[3] = BCD2UpperCh(month);
date[4] = BCD2LowerCh(month);
date[6] = BCD2UpperCh(year);
date[7] = BCD2LowerCh(year);
if(ap)
time[9] = 'P';
time[10] = 'M';
else
time[9] = 'A';
time[10] = 'M';
Glcd_Write_Char( time, 80, 2, 2);
Glcd_Write_Char( date, 70, 6, 2);
Delay_ms(100);
}while(1);
