problem in DC motor control using L293D IC
Discussion in 'Embedded Systems and Microcontrollers' started by spidermanIIII, Feb 5, 2016.
  1. spidermanIIII
    Nov 22, 2013
    76
    hi, I asked to do DC motor control dirctional and speed by using L293D IC, I wrote the code and directional control is done but I have a problem in speed control using PWM it doesn't read the value of potentiometer .please help me
    [quote ]
    int mf=13; //motor forward pin
    int mr=12; //motor reverse pin
    int bf=7; //button for forward move
    int br=6; //button for reverse move
    int en=9; //to enable pin of L239D
    int speedo=0;//the value of analogeread
    int an=A0; //pin use to read potentiometer
    void setup() {
    // put your setup code here, to run once:
    pinMode(mf,OUTPUT);
    pinMode(mr,OUTPUT);
    pinMode(bf,INPUT);
    pinMode(br,INPUT);
    void loop() {
    // put your main code here, to run repeatedly:
    if(digitalRead(bf)==HIGH && digitalRead(br)==LOW){
    digitalWrite(mf,HIGH);
    digitalWrite(mr,LOW);
    else if(digitalRead(br)==HIGH && digitalRead(bf)==LOW){
    digitalWrite(mf,LOW);
    digitalWrite(mr,HIGH);
    else{
    speedo=analogRead(an);
    analogWrite(en,speedo/4);
    delay(50);
    [/quote]
