Problem in Combining Two Voltage Regulators (AMS1117 3.3) (LM7809)
Discussion in 'Power Electronics' started by Anant Singh 1, Aug 4, 2016.
  1. Anant Singh 1
    Aug 4, 2016
    5
    Hello
    I'm making a robot, for that i need various power supplies.
    The problem is my battery is of 15 volts and I need a 3.3 power supply for a part (although I need many more levels but, they are working fine except 3.3) , for that i used AMS1117 3.3 voltage regulator combined with LM7809 as AMS1117 can only take upto 12 volts only. But a lot of heat is being produced as soon as I apply load on the regulator. Current from the IC is around 250mA (which is not a sufficient reason for this much heat). I do not know much about the internal circuits of these ICs. Also it gives 3.3 voltage at no load.
    Please help, suggest a better circuit or the cause of the heat production from the regulator..
    Feel free to ask for any further details..
  2. Bordodynov
    May 20, 2015
    673
    194
    P=250mA*(16V-3.3V)=3175mW=3.175W
    LM7809 --> P1=250mA*(16V-9V)= 1750mW
    AMS1117-->P2=250mA*(9V-3.3V)=1425mW
    For these two chips are required to remove the heat radiators. Otherwise, they will be warmer than 100 degrees Celsius.
    An alternative is to apply the dc/dc converter. This will improve efficiency and reduce current consumption from the battery 3-4 times.
    Anant Singh 1, Anant Singh and absf like this.
  3. dannyf
    Sep 13, 2015
    2,196
    417
    Wrong expectation.
    Anant Singh 1 likes this.
  4. dl324
    Distinguished Member
    Mar 30, 2015
    3,378
    651
    Welcome to AAC!
    As indicated, the 9V and 3V regulators will be dissipating several watts. You'd be better off using a switching regulator for the 3.3V supply or use a switching preregulator instead of the 7809.
  5. AnalogKid
    Aug 1, 2013
    4,696
    1,297
    ebay has many low cost buck regulators that can take 15 V down to 3.3 V in one stage with 85% efficiency or better. This would reduce the total regulator power dissipation to less than 0.5 W. The switching device will be warm to the touch, but it won't melt your fingerprints.
    ak
  6. Anant Singh 1
    Aug 4, 2016
    5
    (melt) haha.....
  7. Anant Singh 1
    Aug 4, 2016
    5
    As i told i don't know much about... :)
  8. Anant Singh 1
    Aug 4, 2016
    5
    thanks a lot everyone, for making me correct and for suggestions...
  9. AnalogKid
    Aug 1, 2013
    4,696
    1,297
    Sounds like a funny exaggeration, I know. But ... it isn't. Ask anyone who has dealt with power electronics or soldering irons for a while, and you'll see this is a real thing. I takes only a few milliseconds for accidental contact with a soldering iron to melt/singe/fry the skin, and an overheated power transistor or resistor can do it almost as fast. By the time you feel it, it's too late.
    ak
  10. Anant Singh 1
    Aug 4, 2016
    5
    @AnalogKid
    I said i don't know much, It doesn't mean I'm a totally nincompoop :)
    I am an Electronics Engineering Student.
  11. ci139
    Member
    Jul 11, 2016
    341
    39
