Problem in Capacitors Explode
Discussion in 'General Electronics Chat' started by munaveed2002, Feb 6, 2013.
Thread Status:
Not open for further replies.
  1. munaveed2002
    Sep 4, 2011
    The two capacitors, C1 and C10 are exploding... dont know why..:(..
    replaced them 4 times. applying same ratings and since these capacitors are polar so, carefully soldering (means + with + and - with -). But couldn't get out of problem. also 10 Ohm resistance also gets damage at same time of exploding. Input are 240volts. and C1 and C10 are of 400v.
    Help...
      File size:
      51.7 KB
      44
  2. BReeves
    Member
    Nov 24, 2012
    412
    64
    Shorted diode(s) in the bridge letting AC get to the caps.
  3. ErnieM
    Apr 24, 2011
    7,447
    1,628
    What *peak* voltage will that create?
    Check the TOS here. Direct to line projects are not allowed.
  4. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    ? Transformerless power supplies are not allowed.
    Normally people building these SMPS circuits are experienced, it is not beginners stuff. Often as much as to know where to search for problems.
    And I think too it's a bad bridge.
  5. t06afre
    May 11, 2009
    5,939
    1,222
    It is a primary switched power supply. As I know this is still inside the cope of the forum, and the TOS. As we allow questions about light dimmers and linear power supplies build from start in this forum.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics.
    The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
Thread Status:
