Problem generating sine waves in Matlab
Discussion in 'Programmer's Corner' started by vince365, Mar 2, 2007.
  1. vince365
    Mar 2, 2007
    I know this is a really basic question to post here, but I just can't figure out why my simple matlab code below isn't working!
    I'm playing with FFT analysis and to run some tests I want to generate a sampled data set that is constructed from every fundamental frequency of each FFT bin.
    I'm emulating sampled audio at 44.1K and want to generate a 2048 sample window.
    I have defined the following variables:
    fs = 44100; % sampling rate
    sp = 1/fs; % sampling period
    ns = 2048; % number of samples
    br = fs/ns; % fft bin resolution = 21.5332 Hz
    Therefore each FFT bin will center at multiples of 21.5332 Hz.
    To generate the wave I'm using the loop below, but the resulting waveform has a nasty spikes at the beginning and end of the sample window:
    y = zeros(1,ns);
    % generate sample made up of the FFT bin centre ffrequencies
    for i = br:br:fs/2,
    y = y + sin(2*pi*i*[0: sp: ((ns-1)*sp) ]);
    end
    I've attached a plot of (y). What am I doing wrong????
    Thanks,
    Vince.
  2. Murod
    Dec 24, 2005
    30
    what do you mean with "fundamental frequency of each FFT bin"?
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    For a given sample the number of FFT points gives the frequency resolution, that is frequencies represented by a single bar. An FFT bar is referred to as a FFT bin when you want to characterise the energy/voltage from a frequency range, not a single frequency. This frequency range has a fundamental frequency.
    Dave
