problem creating noise source
Discussion in 'General Electronics Chat' started by mpradhan, Feb 25, 2009.
  1. mpradhan
    Feb 25, 2009
    Hi I am trying to create or produce noise in my circuit which deals with the design of a lock in detection system. I have already tried using a zener diode in reverse biase mode but did not get any results. Is there any other way of producing noise ? Thanks
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    What was the circuit diagram, and what is the low and high frequency cutoffs?
    I've always heard you need a lot of gain after a low level noise source, so I have to ask what kind of amplification you used.
  3. KL7AJ
    Nov 4, 2008
    2,043
    292
    It's better to use a dedicated noise diode
    http://www.noisecom.com/products_noise_diodes.asp
    I've usually been able to get a couple of free samples from these guys.
    Eric
  4. KL7AJ
    Nov 4, 2008
    2,043
    292
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    What is the frequency range of the noise ?
    Is it in audio range or do you need RF noise ?
    Do you need "pink" or "white" noise ?
    Greetings,
    Bertus
