Problem by printing my pcb from Ultiboard
Discussion in 'General Electronics Chat' started by Chris-nk, Mar 1, 2015.
  1. Chris-nk
    Mar 1, 2015
    19
    Hi folks! I'm new here and I need some advice whit prnting a pcb from Ultiboard.
    The problem is:
    I made a pcb in Ultiboard version 10 and printed out on a paper and I can see does not the exact layout what I have on my screen.
    Here is what I got out from my printer:
    And here is what it should be:
    So, the problem is if you watch in the right down side corner you can see the pads should be square but there are not square in the printed version.
    I changed the pads thickness with the option "In-place PCB Edit" and all the pads a bigger now on the screen but I can not print out like I wish it to be.
    All the time Ultiboard prints the pads as I newer changed them...
    Any advice pls...
  2. GopherT
    Nov 23, 2012
    6,326
    4,054
    @Chris-nk
    I think you are adjusting the pad size/shape on the top layer while printing the bottom layer.
    Chris-nk likes this.
  3. Chris-nk
    Mar 1, 2015
    19
    THNX!!! that was the problem... :)
  4. ErnieM
    Apr 24, 2011
    7,442
    1,628
    I do see "air" wires indicating there are still unrouted connections.
  5. Chris-nk
    Mar 1, 2015
    19
    ErnieM:
    If I check te pcb whit the error checking option in Ultiboard then a got no errors...
