I am using Altium Designer Summer08 and a Nanobord 3000. I made a data memory, and when i try to compile I get this error: BLOCK RAM inferencing failed, output is not synchronous. For this error I use Altium synthesizer, but if I switch to DXP synthesizer it compile, but the wave I see with the LAX is not what I expected.
Code for memory:
What can I do?
Thanks!
Code for memory:
Rich (BB code):
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity memory_data is
port (di_bus : in STD_LOGIC_VECTOR(15 downto 0);
ddo_bus : out STD_LOGIC_VECTOR(15 downto 0);
a_bus : in STD_LOGIC_VECTOR(9 downto 0);
nce : in STD_LOGIC;
rd, wr : in STD_LOGIC;
dready : out STD_LOGIC);
end memory_data;
architecture bhv of memory_data is
type memory_array_data is array (0 to 31) of STD_LOGIC_VECTOR(15 downto 0);
begin
dready <= '1';
process (nce, rd, wr, di_bus, a_bus) is
variable mem_data : memory_array_data;
begin
if nce = '0' then
if rd = '1' then
ddo_bus <= mem_data(conv_integer(a_bus));
end if;
if wr = '1' then
mem_data(address) := di_bus;
end if;
end if;
end process;
end architecture bhv;
Thanks!
