problem 0f 7490 in counting
Discussion in 'The Projects Forum' started by Afeesh a n, Jun 12, 2009.
  1. Afeesh a n
    Jun 12, 2009
    hi,
    i have configured a 7490 as a decade counter. but as the pulse come the counter is counting with 2 ie. 1 3 5 ......what may be the problem the pulses are coming from a monostable multivibrator with time period of .6s.so plz do suggest some idea to eliminate this.
    thank u
  2. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    Can you post a schematic of how you have connected the 7490?
    Greetings,
    Bertus
  3. RiJoRI
    Aug 15, 2007
    536
    26
    And while you're posting the schematic, make sure the LSB is not tied high.
    --Rich
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Are you using bypass capacitors on both your astable multivibrator's Vcc/GND supply AND the 7490 supply pins? If not, there's a very likely cause.
    Are your interconnecting traces/wires/jumpers long? Try to keep them as short as possible; long wires have a good deal of inductance, and will cause circuits to oscillate unexpectedly.
