Hi all,
I know this may be wrong section for this but my problem is Microcontroller programming specific (AVR mostly)!
I am sending bytes between two AVR atmega8 using Uart where each bit in the byte stands for something and only one bit is 1 in each byte sent
So if I want to check, say for example, 5th bit in the received byte then if write it as follows:
Then it works fine always
BUT, if I write it as this:
Then it won't work , also it fails if I use Switch-case instead of if-else
I can't understand the problem, does the compiler interprets it as signed no and 7th Bit as sign?
or something else?
If someone asks I also have LEDs on the receiver that shows received byte
and so I know the byte received is correct but for some reason I cannot compare it for conditions! still can there some noise that causes bits to be misunderstood by the Uart and thus changing the actual byte received?
Help !
Rich (BB code):
short byte=UDR;
if(byte&(1<<5))
// do stuff for bit 5
Rich (BB code):
short byte=UDR;
if(byte==0b00100000)
OR
short byte=UDR;
if(byte==0x20)
or something else?
Help !
