Probably a stupid question, reading pin input levels with Hi-Tech C?
Discussion in 'Embedded Systems and Microcontrollers' started by GuitarMan216, Apr 4, 2012.
  1. GuitarMan216
    Oct 6, 2011
    18
    I'm working on a program, and in a nutshell, I just need to know how to tell if the PORTD pins are high or low, based on push buttons.
    Wasn't sure if I could do a if(RD0<1) blah blah blah.
    Sorry, tried searching, couldn't find an answer. I'll keep searching.
    Thanks for your help!
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
    You could try something like this:
    Code ( (Unknown Language)):
    1.
    2. while (1)
    3. {
    4.   if (RD0)
    5.   {
    6.      do some code
    7.    }
    8.   if (RD1)
    9.   {
    10.      do some other code
    11.    }
    12. else
    13.    {
    14.      do something complete different
    15.    }
    16. } // end while
    17.
    18.
    19.
    I'm sure there are other way to do it. :)
  3. GuitarMan216
    Oct 6, 2011
    18
    What exactly is the while(1) doing? And is the if(RD0) checking if RD0 is high?
    Thanks again.
  4. nerdegutta
    Dec 15, 2009
    2,565
    805
    The
    1.
    2. while (1)
    3. {
    4.   do something forever
    5. }
    6.
    Is an endless loop, since 1 is not changing.
    1.
    2. if (RD0)
    3. {
    4.    do some code
    5. }
    6.
    Checks if RD0 is 1 or high. You could write:
    1.
    2. if (RD0==1)
    3. {
    4.   do some code
    5. }
    6.
  5. GuitarMan216
    Oct 6, 2011
    18
    Ok, so my original idea of if(RD0<1) would suffice? If that'll work, I think I'm good to go. Just wasn't sure how Hi Tech C dealt with the inputs. I'm more interested in when it's low, than high.
    Thanks again, I appreciate it.
  6. GuitarMan216
    Oct 6, 2011
    18
    Just in case someone searches this for similar advice, I went with this code, and it works like a charm.
    Thanks guys.
    1.
    2. if(RD0==0)
    3. {
    4.     String=E_S;
    5.     Tolerance=.224;
    6.     TRISA=0b00100010;
    7. }
    8.
    9. if(RD1==0)
    10. {
    11.     String=A_S;
    12.     Tolerance=.300;
    13.     TRISA=0b00000001;
    14. }
    15.
    16. if(RD2==0)
    17. {
    18.     String=D_S;
    19.     Tolerance=.4008;
    20.     TRISA=0b00011000;
    21. }
    22.
    23. if(RD3==0)
    24. {
    25.     String=G_S;
    26.     Tolerance=.535;
    27.     TRISA=0b00100100;
    28. }
    29.
    30. if(RD4==0)
    31. {
    32.     String=B_S;
    33.     Tolerance=.674;
    34.     TRISA=0b00110000;
    35. }
    36.
    37. if(RD5==0)
    38. {
    39.     String=EH_S;
    40.     Tolerance=.899;
    41.     TRISA=0b00100010;
    42. }
    43.
