Prob: IR Tranceiver from RS232 port
Discussion in 'General Electronics Chat' started by geobabu, Apr 21, 2009.
  1. geobabu
    Aug 13, 2008
    HI,
    I tried to setup a circuit which is basically an IR Transciver module which directly connects to the RS232 Level port without any IC.(Please refer the attached Circuit). The problem is its possible to receive the data. But can't able transmit. I tried the same ciruit, twice, but results the same issue. Please help me , to trace out the issue.
    Regards,
    Geo
      File size:
      49.5 KB
      30
  2. Chartman
    Jan 28, 2007
    You need a 40Khz modulator on the IR transmitter.....
  3. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    Can you clarify what the pins on the 9 pin connector are? Which one is transmit, receive, power, ground, etc...? That would definitely help anyone trying to trace this out with you.
