Hi guys,
I'm looking for a very small pressure sensor.
It has to read a pressures in the 3-6 psi range.
It shoudln't be barometric , I need to hook it up in front of a valve to read the pressure(air) at that point in the fluid circuit, and I also need to mount it on a pcb.
Voltage isn't that important because I can just hook it up to a power supply but preferably in the 3 volt range.
The smallest I've found so far is .3*.25*.4(inches)(from allsensors.com). Is this as small as I'm going to find? I've been able to find much smaller barometric sensor(the epcos sensor is 1.7*1.7*.9) but not one that I need.
