Pressure sensing unit
Discussion in 'The Projects Forum' started by AnitaChoppa, Dec 14, 2013.
  1. AnitaChoppa
    Dec 13, 2013
    I am designing a pressure sensing circuit using SMARTEC SPD005G to sense 10KPA AND 1KPA pressure.
    This is the first time I am dealing with a pressure IC.
    The output of this IC is in mV and I will need to amplify it.
    However, I am not able to determine on how to distinguish the two required pressure for the same IC as for 10KPA the output should be an alarm and for 1KPA the system should shut off it will further be given to the microcontroller.
    Please help me as I have just graduated and do not have much experience.
  2. Dodgydave
    Jun 22, 2012
    5,141
    767
    Read the datasheet, looks like it gives out 65mV @ 35Kpa, 140mV @ 100Kpa,
  3. paulktreg
    Distinguished Member
    Jun 2, 2008
    622
    124
    Have you thought about using their UTI?
