pressure guages
Discussion in 'General Electronics Chat' started by broncosplott, May 5, 2012.
  1. broncosplott
    May 5, 2012
    Hi.can an air pressure guage be used for oil pressure as well?regards,Brian.
  2. #12
    Nov 30, 2010
    16,685
    7,327
    Yes. I've adapted my Freon gauges to test the oil pressure in automatic transmissions.
    Whether YOUR air pressure gauge will survive this, I don't know.
  3. broncosplott
    May 5, 2012
    Many thanks!
  4. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    as long as you understand the pressure capabilities of the gauge and the system under test.
  5. broncosplott
    May 5, 2012
    Hi thanks,it on a diesel engine?
  6. #12
    Nov 30, 2010
    16,685
    7,327
    Coolant system pressure? Oil pressure? Fuel injector pressure? Fuel pump pressure? Brake line pressure?
    Whatever it is, look up the proper pressure so you don't blow up your gauge.
  7. broncosplott
    May 5, 2012
    Hi,the oil pressure,regards,Brian
