I am trying to build a "simplified keyboard encoding circuit" found in my textbook, but I cannot understand one part. Namely, "there are two 74HC195 4-bit shift registers connected as an 8-bit ring counter with fixed bit pattern of seven 1s and one 0 preset into it when the powers turns on."
I know that the parallel-in/parallel-out register loads data when LOAD is HIGH, but how do I load the data only one time - when power is turned on? That is, when power is turned on, the counter loads data, but from that point on, it shift data indefinitely. I cannot think of any workable device that can be applied here.
Any ideas?
Any ideas?
