precision rectifier
Discussion in 'Homework Help' started by shruthi kashyap, Nov 18, 2011.
  1. shruthi kashyap
    Nov 18, 2011
    can any one tell me why the word precision is used in precision rectifier and what is the difference between precision rectifier and the normal rectifier... it`s urgent
  2. MrChips
    Oct 2, 2009
    12,635
    3,454
    A simple rectifier circuit uses a diode. The input voltage has to exceed the turn-on voltage (0.6V for ordinary Si diode) before rectification is achieved.
    A precision rectifier is an active circuit using an opamp and a diode in the feedback loop. This overcomes the turn-on "knee" voltage.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    To add to what MC said, this is useful for test equipment, where eliminating extra variables is required.
  4. crutschow
    Mar 14, 2008
    13,498
    3,374
    The op amp reduces the turn-on voltage of a diode in its feedback loop by a factor equal to the open-loop gain of the op amp. For practical op amp gains this reduces the forward voltage to a fraction of a mV, thus giving a "precision" or near ideal diode characteristic for the rectifier function.
