Precision half-wave rectifier
Discussion in 'General Electronics Chat' started by Vorador, Oct 12, 2013.
  1. Vorador
    Oct 5, 2012
    87
    Hello everyone,
    Could anyone please explain how a silicon diode with a forward voltage of about 0.7V is turned on in a precision half-wave rectifier, even when the input is so much smaller than the forward voltage? Also, why isn't the output 0.7V less than the input? I've read my book and searched around on the internet, but I couldn't find any explanation clear enough to help me understand this... :confused:
    Thank you!
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  3. ErnieM
    Apr 24, 2011
    7,436
    1,625
    One word: amplification.
  4. crutschow
    Mar 14, 2008
    13,481
    3,368
    I'd make that two words and add "feedback". ;)
  5. #12
    Nov 30, 2010
    16,671
    7,314
    The op-amp only cares about getting its inputs to be the same voltage. It will provide the extra .7 volts and you can measure that voltage on the output pin. The other side of the diode will be the same voltage as the input pin of the chip because that is the whole purpose of building a precision rectifier.
    Vorador likes this.
  6. Vorador
    Oct 5, 2012
    87
    I thought there would be no amplification if it's behaving like a voltage follower.
    Thanks everyone. Appreciate it.
  7. crutschow
    Mar 14, 2008
    13,481
    3,368
    There is no apparent amplification at the output node and it looks like a follower at that point, but there is across the diode due to the negative feedback.
    Vorador likes this.
