precious booty
Discussion in 'Off-Topic' started by strantor, Jul 9, 2011.
  1. strantor
    Thread Starter AAC Fanatic!
    Oct 3, 2010
    4,302
    1,989
    Check out mah booty!
    Got a bunch of old/defunct test equipment for free!
    (2) Tektronix 2445B 200MHZ Oscilloscopes
    V.A.PHI Volt, Amp, & Power Factor Meter
    Sencore TF151A Transistor & FET tester
    Small CRT unit from a (???)
    Sencore "substitutor" Decade resistor/ capacitor
    HP 5384A Frequency Counter
    HP8647A 250KHz-1000KHz Signal Generator
    Hameg HM8130 Programmable Function Generator
    Simpson 260 VOM (not shown)
    All of them with calibration stickers went out of cal in the late 90's, everything else said "UNCALIBRATED INSTRUMENT - DO NOT USE FOR ACCEPTANCE TESTING" or "FOR PARTS ONLY"
    Only thing I tried so far is the o-scopes. on one, the fan comes on but nothing ever comes up on the CRT. on the other, fan comes on, CRT comes up gradually after about a minute, but the trace doesn't trace when I probe something.
    I guess this will be my new project once I get all my TVs up and running. So basically, my 2012 project(s).
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Guess we can guess what a lot of your questions are going to be centered on in the future. Good luck with getting them running, some potential nice equipment there.
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    strantor likes this.
  4. Robin Mitchell
    Oct 25, 2009
    738
    207
    hmmmm you sexy beast, oh not you strantor, the gorgeous looking oscilloscopes
  5. debe
    Sep 21, 2010
    955
    185
    They should keep you amused for a while!!
  6. strantor
    Oct 3, 2010
    4,302
    1,989
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    The Bama site is great - but they didn't have your Tek 2445b service manual; just the operators' manual (which you do need)
    Lookie what I found- downloadable Tek 2445 service manual:
    http://tinymicros.com/wiki/File:Tektronix_2445_Service_Manual.pdf
    I suggest that you start off by replacing ALL of the old electrolytic caps (because they'll all need replacement sooner or later; most likely sooner) but that's up to you.
  8. nbw
    Member
    May 8, 2011
    36
    10
    Me is envious!! That's some nice gear there. Even if you can't get it running, there'll be some useful scrounge bits. Fire up the iron, slap on some eye protection, and you're all set!
  9. #12
    Nov 30, 2010
    16,705
    7,358
    I refused to look at this for so long...I was afraid you might "like big butts" as the song says.
  10. Georacer
    Nov 25, 2009
    5,151
    1,266
    This is AAC. You should know better.
  11. strantor
    Oct 3, 2010
    4,302
    1,989
    Lol, I do BTW (like big butts)
    but not obese ones
  12. mbohuntr
    Apr 6, 2009
    413
    32
    I think it's called "BOOTY" :D
