preamplifier overvoltage, reverse polarity protection
Discussion in 'General Electronics Chat' started by masudasim, Jun 25, 2011.
  1. masudasim
    Jul 10, 2010
    15
    Hello all
    I have designed a preamplifier which operates on unipolar supply +10V and draws about 20mA to 40mA depending upon jumper setting.Now i need to add reverse polarity protection as well as overvoltage protection (maximum allowable voltage is +15V)
    Kindly tell me is there any simple solution available?
    Best Regards
  2. tom66
    May 9, 2009
    2,613
    214
    It depends on what you mean by simple.
    A circuit that uses the LTC4365 can do this, but it is an SMD IC, using an SMD MOSFET and a few other SMD components - in other words, it can be tricky to solder.
    A 15V zener across the supply with a fuse in line will blow the fuse if the voltage exceeds 15V or drops below -0.7V, but you will need to replace the fuse every time someone does this.
  3. #12
    Nov 30, 2010
    16,679
    7,322
    This same question just came in on a homework job.
    Use a full wave bridge rectifier on the power input so it always routes the polarity correctly, then do the over voltage protection. The "simple" way is the fuse and zener.
