Preamplifier Design
Discussion in 'Homework Help' started by KuBU, May 31, 2007.
  1. KuBU
    Apr 8, 2007
    5
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This appears to be an assignment, so I will move it to a more appropriate section.
    This is your assignment. You have studied electronics for some time, judging by the assignment. The work needs to be yours - we get no grade for doing your work. Come up with a design, post it here, and perhaps we can offer suggestions.
  3. KuBU
    Apr 8, 2007
    5
    sorry for opening topic in wrong place ..
    but i only want initial information.. then i'll design it of course..
    but i couldn't know "if ishould use 3 or 5 transistors " or some initial information like this..
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Doesn't the assignment sheet say something about a minimum number of transistors?
  5. KuBU
    Apr 8, 2007
    5
    there's not a min. border..
    but we'll use maximum 7 transistors..
  6. mozikluv
    Jan 22, 2004
    1,437
    wow using seven transistors for a preamp is quite a hefty design. since there's no minimum #s of transistors to use, why not make a low noise preamp by using a FET for your input and a regular bipolar as your output.:)
    moz
